I commonly get this error on my screen when i press play it works again, but it often happens again, i already have opened a port on my att fiber router but nothing is there anything else i can do?
Maybe when this error occurs,
Channels could automatically issue a "Play" command,
Maye it could be a feature to enable or disable.
There would likely be a slight momentary "glitch" in the playback.
When I get this message in Channels and play the same link in VLC or TiViMate
it automatically keeps playing but with that slight millisecond glitch.
so you dont know of a fix?
Its likely your iptv provider. Post some logs from when this happens.
I will try to get some logs, but just a quick question, if it is the iptv provider would that mean that it is out of my control other than of course changing provider,or is there anything i could do?
thanks in advance
The issue is most iptv providers are illegal and unreliable so they are spotty at best. If you post logs it will probably just confirm that they are dropping
i understand and i appreciate your help, but Is there anything I can do about it lol?
Run the troubleshooter on the server? Any issues?
Submit diags from server and client.
Lok at logs and see what they say when u get disconnect.
No fix I know of, only hope is if Devs do an automatic Play command and still it may be too glitchy.
See slapmans response.
Ok thanks
