Using HD HomeRun Prime on FiOS 1 "gig" in Western NY as source. Seems to affect only sports network channels: occasionally (average 10- 20 mins) Connection Lost screen appears (Android TV client) or window closes or freezes on web browser, reselect from guide brings it up fine but it's annoying. Server is on Windows 10 Pro. Here is a snip of log that seems relevant, time wise:
2024/12/03 20:15:42.694786 [ENC] Encoder stopped for ch577 in G:\channels-data\Streaming\ch577-d1317BA62-ip100.106.8.125-2465853196\encoder-1-3728531093 after encoding 1 to 327
2024/12/03 20:15:42.848266 [ENC] Starting encoder for ch577 in G:\channels-data\Streaming\ch577-d1317BA62-ip100.106.8.125-2465853196\encoder-328-1282942696 at 328 (326.121300) (encoder=libx264, codec=h264, acodec=aac, resolution=720, deinterlacer=blend, bitrate=1744, segment_size=0.01)
2024/12/03 20:15:42.981334 [HLS] Couldn't generate stream playlist for ch577-d1317BA62-ip100.106.8.125: Couldn't find playlist: G:\channels-data\Streaming\ch577-d1317BA62-ip100.106.8.125-2465853196\remux\stream.m3u8: CreateFile G:\channels-data\Streaming\ch577-d1317BA62-ip100.106.8.125-2465853196\remux\stream.m3u8: The system cannot find the file specified.
2024/12/03 20:15:42.981334 [HLS] Stopping transcoder session ch577-d1317BA62-ip100.106.8.125 (out=5m29.724911s finished=false first_seq=1 last_seq=328)
2024/12/03 20:15:42.989443 [TNR] Closed connection to 1317BA62/0 for ch577 MSG HD
2024/12/03 20:15:42.996610 [ENC] Stopped encoder for ch577 in G:\channels-data\Streaming\ch577-d1317BA62-ip100.106.8.125-2465853196\encoder-328-1282942696 after starting from 328 without encoding any segments
2024/12/03 20:15:42.996610 [SNR] Statistics for ch577 MSG HD: ss=94% snq=100% seq=100% bps=18258138,14190240-18454080 pps=1563,1215-1580
2024/12/03 20:15:42.996610 [SNR] Buffer statistics for ch577 MSG HD: buf=0%-1% drop=0%
2024/12/03 20:15:44.573580 [TNR] Opened connection to 1317BA62/0 for ch577 MSG HD
2024/12/03 20:15:44.573580 [HLS] Starting live stream for channel 577 from 100.106.8.125
2024/12/03 20:15:44.895731 [HLS] Probed live stream in 321.6094ms: mpeg2video 1920x1080 tt 5501568bps
2024/12/03 20:15:45.884018 [HLS] Session ch577-d1317BA62-ip100.106.8.125 started in 1.3104379s
Is this something I can fix?
Thx
