Constant buffering issues on Channels DVR (FFMPEG Issue)
That issue is fixed in prerelease.
It seems that I've got everything working now except TVE for local channels. As an aside, a fresh install of the latest stable release behaves the same as the prerelease (all non-local TVE channels were able to be streamed. A Hulu channel scan finds the channels, but no stream. I understand that local TVE is experimental and no fix may exist, but here is the log for one of the failed streams. A bit baffling since these streams worked flawlessly until 3 days ago.
2023/03/31 19:14:20.085605 [TNR] Opened connection to TVE-Hulu for ch6003 KIRO
2023/03/31 19:14:20.091450 [HLS] Starting live stream for channel 6003 from 127.0.0.1 (bitrate=9858)
2023/03/31 19:14:28.489300 [HLS] Stopping transcoder session ch6003-dANY-ip127.0.0.1
2023/03/31 19:14:28.492818 [ERR] Probe failed for live stream after 8.4013686s and 0 bytes
2023/03/31 19:14:28.513361 [HLS] Couldn't generate stream playlist for ch6003-dANY-ip127.0.0.1: Stream stopped
2023/03/31 19:14:28.543379 [HLS] ffmpeg: ch6003-dANY-ip127.0.0.1-remux: Output file #0 does not contain any stream
2023/03/31 19:14:28.570676 [TNR] Closed connection to TVE-Hulu for ch6003 KIRO
