Hi Folks
I have an legacy I7 desktop where I run Window 10 Ver 21H2 Most times when I start Channels I get constant channel buffering with fits and starts with every channel. I notice that when I start to play any channel or station, I also see 2 instances of ffmpeg in Windows Task Manager.
I have a much older and slower I5 desktop that runs Channels much faster and rarely has bufffering problems like this. I also notice that ffmepg does not run on this box when I fire up Channels to watch TV.
Could ffmpeg be my culprit?
Here are some specs on the PC which shouldn't be a problem
Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Memory 32GB DDR3
Video
Name SB270 on NVIDIA GeForce GT 710
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State Enabled, Primary
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Manufacturer NVIDIA
Model GeForce GT 710
Device ID 10DE-128B
Revision A2
Subvendor Gigabyte (1458)
Current Performance Level Level 0
Current GPU Clock 135 MHz
Current Memory Clock 405 MHz
Current Shader Clock 405 MHz
Voltage 0.887 V
Technology 28 nm
Bus Interface PCI Express x8
Temperature 38 °C
Driver version 22.21.13.8476
BIOS Version 80.28.a6.00.4b
Physical Memory 2047 MB
Virtual Memory 2048 MB
Count of performance levels : 1
Level 1 - "Perf Level 0"
GPU Clock 135 MHz
If there any Channels diagnostics please ask and I will provide.
thank you
Jeff
