Constant notifications of lineup changes with HDHomeRun Quatro
@Edwin_Perez please show a screenshot of your sources, if you don't mind.
I'm not sure exactly how HDHR works with Channels.
With the Quatro device, shouldn't there be 4 sources created by Channels since it has 4 tuners? It looks like there are only 2 sources for it.
No Channels shows the Devices not the number of tuners.
HDHR Config ....
Understood.
To help me with the investigation since I don't have any HDHR devices, could you send me your current channel lineup log files created by my script for reference? And then, the next time there is a change, send me the new log files?
My "support" email address sent in PM.
OK I sent the logs I am going to re-enable your scripts.
HDHomeRun QUATRO: 62 channels (-3)
<--- Lineup changes (starting at 10.1) --->
  • 47.1 : KUNP-LD
  • 47.2 : TheNest
  • 47.3 : Charge!
<--- Channel changes --->
  • KUNP-LD (47.1)
  • TheNest (47.2)
<--- Duplicated channels --->
CRIME: 23.2, 8.4
KOXI-CD: 20.1, 20.2, 20.3, 20.4, 20.5, 20.6, 20.8, 20.9
KPXG-LD: 42.1, 42.3
OPEN: 8.5, 8.6
TBD: 2.4, 32.4
I have to disable it again sorry ...
HDHomeRun QUATRO: 65 channels (+3)
  • 47.1 : KUNP-LD
  • 47.2 : TheNest
  • 47.3 : Charge!
  • KUNP-LD (47.1)
  • TheNest (47.2)
CRIME: 23.2, 8.4
Charge!: 2.2, 47.3
KPXG-LD: 42.1, 42.3
OPEN: 8.5, 8.6
TBD: 2.4, 32.4
Of course, no problem, I understand.
Thank you for the logs. I can clearly see that my script combined the two Quatro sources into one, as you mentioned previously. At first, I was not sure what you meant but now that's clear.
I confirm that this is a bug that I need to fix. Sorry for the inconvenience.
I need one more thing from you, if that's fine with you: the text that shows up at http://server_ip:port/devices
sent via email.
@Edwin_Perez I think I have a fix for it but it is not tested. Without hardware, I don't see a way for me to test it, unfortunately.
How do you currently run my script? OliveTin?
OLiveTin
In this case, I will ask @bnhf if he will be so kind to integrate it in OliveTin as a test version. :grimacing:
Test version built as bnhf/olivetin:test with v3.3.0 changes included. @Edwin_Perez Could you let us know if it works? And if so, I'll push it as a new latest.
I have it up and running so far looks good.
Deleted source: "HDHomeRun PRIME"
Deleted source: "HDHomeRun QUATRO"
Deleted source: "HDHR5-4K"
New source with 65 channels: "HDHomeRun QUATRO 107829D3"
See file /config/192.168.50.215-8089_data/HDHomeRun_QUATRO_107829D3.log for the full lineup.
New source with 62 channels: "HDHomeRun QUATRO 10701381"
See file /config/192.168.50.215-8089_data/HDHomeRun_QUATRO_10701381.log for the full lineup.
New source with 72 channels: "HDHR5-4K 1080ACCC"
See file /config/192.168.50.215-8089_data/HDHR5-4K_1080ACCC.log for the full lineup.
New source with 541 channels: "HDHomeRun PRIME 13147C7B"
See file /config/192.168.50.215-8089_data/HDHomeRun_PRIME_13147C7B.log for the full lineup.
New source with 541 channels: "HDHomeRun PRIME 131A192A"
See file /config/192.168.50.215-8089_data/HDHomeRun_PRIME_131A192A.log for the full lineup.
I would be interested if @chDVRuser could give it a try too. I hope that doesn't break any of his HDHR sources.
HDHR all have unique ID's so I doubt it would break anything for anybody. Great Job.
Thank you. That gives me some confidence. :slightly_smiling_face:
It is working great ... no more false alerts ....
Check time: 2024-05-31 17:25:34
Server version: 2024.05.26.0350
No changes found in any source.
Next check: 2024-05-31 17:55:34
OK, great. Pushed with v3.3.0 as bnhf/olivetin:latest (aka bnhf/olivetin:2024.05.31).
Worked fine here. I only have one HDHR Prime.
