Control the 'Storage Path' for recording Series Passes
I have multiple hard drive 'Storage Paths' setup for storing of the DVR recordings. Is it possible to specify for individual Series Passes which 'Storage Path' to use. For example, movies are typically large compared to others. I'd like to record and save these larger recordings on my large spinning hard drive. At the same time, the smaller shows I'd like to record on my internal SSD drive.
This is not possible.
If you'd like to move your movies, you could move them from your DVR storage to their own directory that you import them via Local Content.
Got it - thanks for the workaround Maddox...
If you guys get around to it, be a nice feature to be able to set this up for some scenarios - add it to the backlog!!
If you're using virtualization like Docker or kvm/lxc then you could change the mount points to separate out the /shares/TV and /shares/Movies to the different backing drives.
