Copied virtual channels becomes exact clone
Hi all,
First post on here.
I have found what I believe is a bug. Server is on Ubuntu and clients are all on android or iOS.
Basically I only use channels for the virtual channels feature, which is fantastic. I have found a coincidence that keeps appearing.
My specific example is where I have a channel with a smart rule that is filled with all content with the genre listed as comedy. My two virtual channels in this example are just called Comedy and Comedy 2, listed back to back on the channel guide as channels 69 and 70. I intend for channel 70 to just show more of my comedy content, an extension of channel 69, but what keeps happening after a day or two is channel 70 becomes an exact clone of channel 69. The lusting on channel 70 becomes the exact same as channel 69. Then I delete channel 70 again, click the copy icon next to channel 69 and move the new channel number back up to 70. I am back to what I want: two channels showing different comedy content. By about two days later the two channels are the exact same again. This is happening on the stable and prerelease versions. I'm currently on v2026.10.28.2140 on my server.
I have had this same issue in the past with other virtual channels but they were not as consistent as this specific example. It has been occurring for maybe a couple of months.
Happy to provide logs or more data if needed
What sort mode are you using on these channels?
Season/Episode sort
Edit: this reminds me of another question I have. Is there a sort mode that is random for movies but season/episodes for shows, all in one sort mode? If this exists it would be my default. Season/episode sort mode does not appear to allow a film to interrupt a string of episodes; a movie only pops up when every show's s01e01 episode has been shown, using s01e01 as an example. I am looking for a sort order which will play episodes in order but allows a movie to pop in and interrupt a the string of these s01e01 episodes. I dont want to use random sort order because then it plays episodes of shows out of order
