Could not fetch playlist
I am using channels app remote this week.
I can click on the guide and stream live tv without issue.
But anytime i click on a recording i get could not fetch playlist.
Adding pics of the error and error log.
Thanks
In c:\programdata\channelsdvr\latest is there a ffprobe.exe?
Some other users reported it went missing.
If so, you can update to prerelease and it should redownload.
It was missing
Downloading the beta fixed it
I try not to run my main system on Beta.. when do you think the final release would be so I can switch back
It will switch to the next release automatically.
I wonder what deleted ffprobe.exe. Do you have some kind of virus detection other than windows defender? Any events shown in windows defender about it?
Also can you check in the 08.08 folder in the sha256 file if you open with notepad, does it show ffprobe.exe in there?
Just defender. No events.
