Hi Maddox, it's the install that's not working first. I'm between step 1 and 2 of " Set up your new Channels DVR Server" at the guide. (btw, I've successfully used that guide to move the DVR from windows to mint in the past
Aman,
I had the container shut down, removed the directories related to the dvr (data and so on), then ran the container again. In the docker log (using Portainer), I see
Installing Channels DVR..
Downloading Channels DVR 2020.03.27.1730 (linux-x86_64) to //channels-dvr......
Channels DVR has been downloaded.
Running Channels DVR..
Check the web interface at https://192.168.1.253:8089/, no dice.
the files in data are recreated and in the channels-dvr.log I see:
2020/04/30 22:20:57 couldn't open settings.db: no such device
2020/04/30 22:21:00 couldn't open settings.db: no such device
2020/04/30 22:21:01 couldn't open settings.db: no such device
2020/04/30 22:21:03 couldn't open settings.db: no such device
2020/04/30 22:21:05 couldn't open settings.db: no such device
2020/04/30 22:21:08 couldn't open settings.db: no such device
Btw, OMV is Debian based.
Also, the setup on the mint machine where the working DVR is today looks identical regarding the perms in the data folder...
