I have a couple questions I haven’t seen an answer to as I try to get TVE up and running fully.
-It seems like I can set source priority on every device individually. I’m guessing if I set something to record it will use whatever the primary source on the DVR server software is set to.
-Is there any logic that if I am out of tuners that will cause the app to fall back to the TVE stream?
-Is there any way to force a source for something in the app. Say for some reason I want to use the internet version of a channel instead of from the tuner?
Thanks for the help. Seems like an amazing addition at this point!
