The EPG has lost episode information for my OTA station CoziTV. No season episode numbers. I think it is re-recording shows now. See screenshots.
COZI TV in Des Moines, Iowa also has this problem both on Channels DVR & Tablo DVR.
Weird. I've contacted our provider to see if they can explain this.
Schedules direct does not seem to have it either. The Show ID's Start with SH instead of EP.
This issue has been fixed by our provider.
So just refresh or reload entire guide?
Yep redownload entire guide and it should be fixed.
That did it exceptional support once again ... Thanks.
Works on zap2it also?
Since CONTV is a TVE channel I don’t know what provider to use to check on Zap2it.
