CPU Load
Is there something I need to turn on to see my CPU load?
Version
2020.01.09.0819
OS
Windows Microsoft Windows 10 Pro
10.0.18362 Build 18362
CPU
4 cores / Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
RAM
15.91 GB
75.0% free
Rob
Windows does not report load averages
Any update about this?
What specifically are you wondering about? Windows doesn’t do load averages, that’s a Linux thing...
I'm was curiosity for something similar for windows like the network load? Anyway no a big deal.. I'm just learning Channels DVR.. thanks your respond
Best equivalent is to launch task manager and look at the performance tab. There is a wealth of information there. You can also launch resource monitor from there, which goes into even more detail. :grin:
