Custom Channel Guide Data Question
Noticed over the weekend if I do a manual XMLTV refresh on a custom channel source it pulls data for all custom sources, or it at least looks like it in the log. Is this intended behavior or should it only be refreshing the guide for one source?
Was a known issue. Supposedly fixed in v2024.01.10.2106
When you do the manual XMLTV refresh on your custom channel source, are you seeing Channels DVR fetching guide data in the log for all your XMLTV sources, or just the one you refreshed?
2024/03/05 09:05:02.493086 [DVR] Fetched guide data for XMLTV-Plutojg in 99ms
Correct I missed fetching message and only saw the reindexing ones.
It does look to be working as expected.
