Custom channel info bar
Hi,
Im new enough to channels tv.
Im using channels for my own custom channels, which I stream to the get channels app on my fire stick and iPhone.
After some tv shows, to the start of the new show, I get the info bar at the bottom of the screen.
is there a way I can remove this automatically showing, for some reason it only appears at the beginning of some shows,
Thanks.
