Custom Channels M3U and logos
I have a few custom channel sources and my source has many broken channel logos. On a number of these, I've mapped to a specific channel in the 'Manage Lineup'. When I did this I would expect the logos that are displayed there to be pulled in to Channels for use, but they are not, they are still using the same broken logo.
Would it be possible to add this as an option? To use the channel logo from the guide?
Have you tried Guide Database > Maintenance :gear: Refresh Station Logos
Yep, I tried this earlier and it didn't work.
Are the channel logos missing on the DVR web admin UI grid guide?
Yes, missing from web app and iOS and Android apps. They only show up from viewing in the "Manage Lineup" section.
It works for me.
Screenshot 2023-01-08 at 17-59-21 Channels Guide
I would suggest submitting diagnostics from the DVR web admin UI.
Submitted a ticket and waiting on response now.
If you have logos in your XMLTV file it might be using those instead.
I do and it is, but that is my ask, to have a toggle or some setting to FORCE the use of the guide channel icons rather that what is in my xmltv file as those are highly inconsistent.
Okay that's reasonable. It will take some investigation because it's not a simple change.
That would be great. Thank you!
