Custom channels on adb tuner
where can I get the custom channels information to input in either adb tuner or ah4c, I see on github they have some of the channels but how do you get all of the channels? Thanks in advance! I mean like the channel ID and name? etc!!!
This depends on your Provider .... have you Chosen one or have one ?
I would like to use Hulu and directv?
Someone will have to help you find the direct links ... good luck.
See
