Custom Logos not appearing in CDVR Beta guide Android TV app
I have set up custom logos using embeded url's from OneDrive. It has worked flawlessly for serveral Years. But the last couple of beta releases the logo's will not appear in the guide in the androd app. The embeded url's work in the UI Web guide. Beta (8.12.1947)
I have that issue on the iOS client, but only when connecting outside my home.
Could be to do with the file type.
Had some issues with jpgs saving as webp for some reason, and I would just rename them to .jpg - which would work for some devices, but others would not accept them. So I had to put it through and image converter or find one that would save as a jpg/png.
Could be worth trying a different format.
