@tmm1 It doesn't work if you view from the web console or use hls streaming on a client. In those cases it throws errors in the logs. I submitted diagnostics from the client just now and from the server
4dd03609-c536-46d1-8327-750f38049418. If I turn off hls then it works ok.
2022/11/30 19:56:04.863568 [TNR] Opened connection to M3U-SecurityCameras for ch0.5 All Cameras
2022/11/30 19:56:04.865736 [HLS] Starting live stream for channel 0.5 from 172.16.1.11
2022/11/30 19:56:05.006345 [HLS] ffmpeg: rtsp-MultiCameraView: [rtsp @ 0x7e81600] method SETUP failed: 461 Unsupported transport
2022/11/30 19:56:05.365936 [HLS] Stopping transcoder session ch0.5-dANY-ip172.16.1.11
2022/11/30 19:56:05.366078 [ERR] Probe failed for live stream after 500.103186ms and 0 bytes
2022/11/30 19:56:05.366144 [ERR] Error during stream M3U-SecurityCameras ch0.5 All Cameras: read |0: file already closed
2022/11/30 19:56:05.366164 [TNR] Closed connection to M3U-SecurityCameras for ch0.5 All Cameras
2022/11/30 19:56:05.370240 [HLS] Couldn't generate stream playlist for ch0.5-dANY-ip172.16.1.11: Stream stopped
2022/11/30 19:56:07.066297 [HLS] ffmpeg: rtsp-MultiCameraView: [mpegts @ 0x7ea4ac0] Non-monotonous DTS in output stream 0:0; previous: 26581, current: 0; changing to 26582. This may result in incorrect timestamps in the output file.
2022/11/30 19:56:07.066314 [HLS] ffmpeg: rtsp-MultiCameraView: [mpegts @ 0x7ea4ac0] Non-monotonous DTS in output stream 0:0; previous: 26582, current: 1621; changing to 26583. This may result in incorrect timestamps in the output file.
2022/11/30 19:56:07.066316 [HLS] ffmpeg: rtsp-MultiCameraView: [mpegts @ 0x7ea4ac0] Non-monotonous DTS in output stream 0:0; previous: 26583, current: 7741; changing to 26584. This may result in incorrect timestamps in the output file.
2022/11/30 19:56:07.066319 [HLS] ffmpeg: rtsp-MultiCameraView: [mpegts @ 0x7ea4ac0] Non-monotonous DTS in output stream 0:0; previous: 26584, current: 15481; changing to 26585. This may result in incorrect timestamps in the output file.
2022/11/30 19:56:07.066322 [HLS] ffmpeg: rtsp-MultiCameraView: av_interleaved_write_frame(): Broken pipe
2022/11/30 19:56:07.066408 [HLS] ffmpeg: rtsp-MultiCameraView: Error writing trailer of pipe:: Broken pipe
