I’ve been playing around with the custom m3u playlist using the text function. I’ve found that when copying text from a website or link that it will also transfer the markup and not function properly. I have been using notepad and then copying to fix this, but for the life of me cannot get images to work. I have them set to. 4:3 ratio and even used the same dimensions as the example of the webcam. I have then on OpenDrive abs I am using jpg files and the examples are png. Do the images need to be png format?
Does the image url load from a incognito window?
Yes, it can load from incognito, but I also see the opendrive header. Could opendrive be the issue?
Sounds like it.
