Custom Quick guide?
I saw something about Custom channels. Is there a way to set up a custom Quick guide where I can quickly access my top ten channels?
Indeed there is:
Thanks. I'm not seeing Locals off my Hdhomerun
The other route that does not require custom channel collections is to simply set the Quick Guide to your favorites. Then, in the client app, go to Settings > Manage Sources to select which sources are visible, and mark your favorite channels.
Remember, the favorite/disabled status of a channel is a client/device setting. It is not synced across apps, and it is different than the favorites or source priority on the DVR server.
Just came across your post. I’m new to Channels and now wondering what the purpose of the favorites on the DVR server is. I mistakenly thought guide and favorites synced across all clients.
Favorites on the DVR can help prioritize channels when a program may air on multiple channels.
Unfortunately, favorites are local to the client device. If you want to keep groups of channels in sync across clients, then you should look into Channel Collections:
Excellent tip. Thank you!
