Customize Channel (EPG guide not showing up)
I have been trying to create a custom from an IPTV service. I have been successful in using m3u4u.com to create a customized channel. I have been limiting the number of channels to less than 500. Under the custom channels dialog box I include the source which is a .m3u extension that comes from m3u4u and also includes the XMLTV Guide Data which is a .xml extension and comes from m3u4u.
On Channels DVR the channels show up fine, but the Guide data (EPG) is now showing up. I have no idea what I am doing wrong. Has anyone had any success with using m3u4u.com and Channels DVR?
Thank you in advance.
Screenshot of your setup please. That will help people identify potential errors.
I resolved the issue. Sorry for the false alarm
It’s helpful to report what helped you resolve the issue for other members that might come across your post in the future with the same kind of issue.
Can you please share yow you fixed this. I have the same issue.
