Default Padding per source please
Hi, Have 8 sources and the all require a different padding when setting up a pass/recording. Would it be possible to ad an option to set the default padding per source? My requirement is anywhere from 48 secs to 4 minutes. Would be nice just to schedule a pass or program from the guide and have the padding automatically applied based on the source. I would also be nice if the end padding mirrored the start padding by default, then could be over ridden if needed. Thanks
To be honest, if you have a source that needs 4 minutes of padding, that’s an bit outside of what we need to support in the app.
While aCustom Channels is a feature we provide, it’s a bit up to you on what you’re adding to Channels.
Channels will continue to be designed around a bit more reliable sources that we natively support, and this isn’t something that they require.
I’ll remind that each pass has its own padding settings that you can apply any way you want.
