Updated Android client to 2.29.238 and then channel hopped through 5 of my Vu Sat channels.
Submitted diagnostics
29fd44c0-18fc-4299-9d0e-c2c5cfb1e75a
I don't know if you were expecting any improvements in the beta or if you have just added more diagnostics, but I would say the channel change time was much the same as before. I also still had the odd channel that won't load fully, either giving audio with no picture, or nothing at all. It doesn't seem to be related to a specific channel as a couple of minutes later when channel hopping back down the list the same channel that was previously an issue will then load fine.
The firmware I have on the Vu is "Openvix" which is a long standing open source system for multiple "Enigma2" family of satellite boxes.
My Openvix version isn't the absolute latest available (maybe 6 months and 1 version out of date) but I've loaded the exact same M3U file from it as I used for the Custom Channel on Channels into VLC and that channel hops fine always within a second or two.
I can update OpenVix to the latest if you think it might help but as SWMBO is using that as the main TV while I "tinker" around with Channels, it comes with a risk to my health!
