I am seeing an issue that seems to only occur if I try to fast-forward on a show that is being recorded at the time.
Ex: News starts recording at 0430, I begin to watch it from the beginning around 0500 and will often (but not every time) get a lag when I try to skip commercials. I have it set for 15s skip and the news is infested with commercials so it is used often.
I tend to not see this when the show is fully recorded.
Running on an Nvidia Shield Pro with server and client on the same device. CPU does not appear to be under duress during this time.
Tuners are on the same switch so they are logically close. I don't see any lag during playback, only when skipping forward/back.
