Device logs on firetv and freezing
Trying to troubleshoot a client that freezes every now and again. I submitted some logs last night if the DEV's could take a look.
In the meantime, I have read in the forums that I can view the device logs using http://192.168.x.x:57000/log
I am not able to view the logs using this URL. I have channels running while attempting this. I am using a firetv stick. What am I missing?
I just submitted another set of logs as my playback stopped again for a few seconds.
When this happens:
  1. I can be behind in the timeline or live.
  2. I can rewind to where the pause is/was and it does not do it again (I take this to mean it isn't in the stream itself).
  3. Seems to happen on TVE and / or HDHomerun channels.
Any clue to what you see might help me.
Thanks
worked out getting to the logs. Just submitted more diags... I do see this, is it significant?
11-10 08:55:52.674 6751 6788 V mpv : [cplayer] Enter buffering (buffer went from 100% -> 0%) [0.000000s].
11-10 08:55:52.675 6751 6788 V mpv : property: buffering = true
11-10 08:55:52.677 6751 6751 I Choreographer: Skipped 154 frames! The application may be doing too much work on its main thread.
11-10 08:55:52.680 6751 6751 V mpvstats: AV: 1149.167 A-V: 0.000 Dropped: 4 Cache: 0.000s video + 0.000s audio
11-10 08:55:52.680 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 08:55:52.680 6751 6751 V PlayerActivity: state PLAYING -> BUFFERING
11-10 09:03:01.450 6751 6751 V mpvstats: AV: 66.655 A-V: 0.000 Dropped: 0 Cache: 5.205s video + 5.035s audio
11-10 09:03:01.450 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:04.451 6751 6751 V mpvstats: AV: 69.658 A-V: 0.000 Dropped: 0 Cache: 5.205s video + 5.035s audio
11-10 09:03:04.451 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:07.452 6751 6751 V mpvstats: AV: 72.661 A-V: 0.000 Dropped: 0 Cache: 5.239s video + 5.035s audio
11-10 09:03:07.452 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:10.453 6751 6751 V mpvstats: AV: 75.664 A-V: 0.000 Dropped: 0 Cache: 5.205s video + 5.035s audio
11-10 09:03:10.453 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:13.454 6751 6751 V mpvstats: AV: 78.667 A-V: 0.000 Dropped: 0 Cache: 5.205s video + 5.035s audio
11-10 09:03:13.454 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:16.455 6751 6751 V mpvstats: AV: 81.670 A-V: 0.000 Dropped: 0 Cache: 5.239s video + 5.035s audio
11-10 09:03:16.456 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:19.456 6751 6751 V mpvstats: AV: 84.673 A-V: 0.000 Dropped: 0 Cache: 5.105s video + 4.907s audio
11-10 09:03:19.456 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:22.456 6751 6751 V mpvstats: AV: 87.676 A-V: 0.000 Dropped: 0 Cache: 2.102s video + 1.920s audio
11-10 09:03:22.456 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:24.636 6751 6788 V mpv : event: unpause
11-10 09:03:24.637 6751 6788 V mpv : [cplayer] Enter buffering (buffer went from 100% -> 0%) [0.000000s].
11-10 09:03:24.637 6751 6788 V mpv : property: buffering = true
11-10 09:03:24.637 6751 6751 V PlayerActivity: state PLAYING -> BUFFERING
11-10 09:03:24.638 6751 6751 V mpvstats: demuxer-cache-state: {cache-end=90.02666644444444, reader-pts=90.02666644444444, cache-duration=0.0, eof=false, underrun=true, idle=false, total-bytes=60301584, fw-bytes=0, raw-input-rate=592820, debug-low-level-seeks=0, debug-byte-level-seeks=1, debug-ts-last=88.64388911111111, ts-per-stream=[{type=video, duration=0.0, reader=90.01191111111112, end=90.01191111111112}, {type=audio, duration=0.0, reader=90.06004444444444, end=90.06004444444444}], bof-cached=true, eof-cached=false, seekable-ranges=[{start=-2.222222222209025E-7, end=86.0079108888889}]}
11-10 09:03:25.457 6751 6751 V mpvstats: AV: 89.812 A-V: 0.000 Dropped: 0 Cache: 0.000s video + 0.000s audio
11-10 09:03:25.457 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:26.197 6751 6788 V mpv : [cplayer] Still buffering (buffer went from 0% -> 3%) [0.033356s].
11-10 09:03:26.201 6751 6788 V mpv : [cplayer] Still buffering (buffer went from 3% -> 25%) [0.256000s].
11-10 09:03:26.373 6751 6788 V mpv : event: unpause
11-10 09:03:26.374 6751 6788 V mpv : [cplayer] End buffering (waited 1.736899 secs) [5.034667s].
11-10 09:03:26.380 6751 6788 V mpv : property: buffering = false
11-10 09:03:26.380 6751 6751 V PlayerActivity: state BUFFERING -> PLAYING
11-10 09:03:26.389 6751 6751 V mpvstats: demuxer-cache-state: {cache-end=95.44533311111111, reader-pts=90.41066644444444, cache-duration=5.034666666666666, eof=false, underrun=false, idle=true, total-bytes=63925736, fw-bytes=3582912, raw-input-rate=308368, debug-low-level-seeks=0, debug-byte-level-seeks=1, debug-ts-last=95.47871111111111, ts-per-stream=[{type=video, duration=5.3386666666666684, reader=90.07864444444445, end=95.41731111111112}, {type=audio, duration=5.034666666666666, reader=90.44404444444444, end=95.47871111111111}], bof-cached=true, eof-cached=false, seekable-ranges=[{start=-2.222222222209025E-7, end=94.18274422222223}]}
11-10 09:03:26.592 6751 8787 V libchannels: libchannels: creating new segment at idx=1
11-10 09:03:27.158 6751 6751 V mpvstats: AV: 90.713 A-V: 0.000 Dropped: 5 Cache: 5.239s video + 5.035s audio
11-10 09:03:28.465 6751 6751 V mpvstats: AV: 92.047 A-V: 0.000 Dropped: 5 Cache: 5.205s video + 5.035s audio
11-10 09:03:28.465 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:31.467 6751 6751 V mpvstats: AV: 95.050 A-V: 0.000 Dropped: 5 Cache: 5.239s video + 5.035s audio
11-10 09:03:31.468 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:31.632 6751 6795 V libchannels: libchannels: rolling over reader to segment with idx=1
11-10 09:03:31.890 6751 6761 I hannels.dvr.ap: Background concurrent copying GC freed 156982(5MB) AllocSpace objects, 0(0B) LOS objects, 8% free, 61MB/67MB, paused 170us total 516.255ms
11-10 09:03:34.345 6751 5469 V ApiServer: REQUEST: GET /log
11-10 09:03:34.469 6751 6751 V mpvstats: AV: 98.053 A-V: 0.000 Dropped: 5 Cache: 5.239s video + 5.035s audio
11-10 09:03:34.469 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:37.470 6751 6751 V mpvstats: AV: 101.056 A-V: 0.000 Dropped: 5 Cache: 5.205s video + 5.035s audio
11-10 09:03:37.470 6751 6751 V streamstats: strength=0% quality=0% symbol=0% rate=0b/sec buf=0%
11-10 09:03:38.420 6751 5469 V ApiServer: REQUEST: GET /log
