Differing show art for “Chicago” series
This is more of a curiosity question: when the current new season of the Chicago shows started (PD, Fire, Med) I noticed the poster art changed for only Chicago Med. it’s certainly not unusual for poster art for shows to change when a new season starts, but I thought it was odd that only 1 out of the 3 changed.
Attached is an example of what I’m seeing. It shows like this both in iOS and Fire TV. I am running the latest stable version of the DVR.
I’m assuming that the show art is controlled by the guide data provider, and there’s really no way to change it manually on my end? I did double check with a Google images search, and there are matching new season poster designs for the remaining 2 shows.
Yes this is controlled by the guide provider and is not user-editable I don’t believe.
Fixed in next pre-release. It should kick in when the next new episode is recorded.
Most excellent, thanks! :+1:
