Just discovered a new OTA channel Digi TV in Denver on channel 14.5. I redownloaded the guide but no luck getting this new channel? Do you know if it is available?
If it just started airing it may take awhile.
Do you see it in the guide at zap2it.com ?
Select Change Provider there, put your zipcode in and choose Antenna - Local Over the Air Broadcast
That uses the same guide data Channels DVR does (Gracenote).
Also check on the official HDHR app to see if it appears there.
Here's a mention of DigiTV for Detroit and why Silicon Dust HDHR doesn't have guide data Detroit channel 38.8 DigiTV - Silicondust
Thanks for the information. I do not see it in zap2it. I'll just need to wait.
