DiIfferent channels pulling from the same source?
This shows that failover works.
Is this source the TVE Custom Channels Source or something else?
Did you do the second test when you try and play the TVE source? If yes, did that work?
How do I DISABLE the failover? I want each discrete channel to be of a different video feed. This setup is kind of stupid.
Failover is desired by most. You need to rename the sources. You would do well to tone down your public behaviour.
Rename the sources to what? They already have different names.
TBH, I don't need or appreciate the lecture from some random person on the internet. If you don't like a person's "public behavior", maybe you should keep that to yourself?
Nobody else has offered to help you and now I'm done. Enjoy the silence
Are you serious? Others are offering help. Maybe you should get off your high horse.
TBH, while you may have "offered" to help, nothing you provided actually did help. So.... thanks for nothing. Your silence will not be missed.
