DirecTV - Cable provider authentication failed - Aug 2025
Currently getting Cable provider authentication failed on all TVE channels using DirecTV. I can visit the sites directly and play live TV though.
2025/08/26 21:43:04.009365 [TVE] action=auth mvpd=DTV requestor=CNN
2025/08/26 21:43:05.028716 [TVE] action=version product=Chrome/139.0.7258.139 jsVersion=13.9.205.20 protocol=1.3 revision=@54b87fe5881df381307c2ef806b8e5e87e8a6790
2025/08/26 21:43:05.050216 [TVE] action=page_ready chromeVersion=139
2025/08/26 21:43:05.052225 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=DTV&requestor_id=CNN&no_iframe=true&domain_name=adobe.com&reg_code=&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2025/08/26 21:43:05.058975 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2025/08/26 21:43:08.767895 [TVE] action=wait_for_page
2025/08/26 21:43:08.855314 [TVE] action=request type=Document method=POST url=https://idp.dtvce.com/dtv-idp-authn/authn/v2
2025/08/26 21:43:08.855314 [TVE] action=auth_domain domain=idp.dtvce.com
2025/08/26 21:43:08.899399 [TVE] action=response url=https://sp.auth.adobe.com/favicon.ico status=404 status_text=
2025/08/26 21:43:09.391828 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authorize redirected_from=https://idp.dtvce.com/dtv-idp-authn/authn/v2
2025/08/26 21:43:15.062008 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authenticate
2025/08/26 21:43:23.337784 [TVE] action=page_ready
2025/08/26 21:43:23.337784 [TVE] action=wait_for_page done=true reason=page_ready
2025/08/26 21:43:23.337784 [TVE] action=wait_for_auth timeout=12s
2025/08/26 21:43:23.337784 [TVE] action=fill_form u=[MY ACCOUNT EMAIL]
2025/08/26 21:43:23.344866 [TVE] action=tvejs msg="directvLogin: no username"
2025/08/26 21:43:23.344866 [TVE] action=tvejs msg="directvLogin: no password"
2025/08/26 21:43:35.338280 [TVE] action=check_result
2025/08/26 21:43:35.343006 [TVE] action=auth_timed_out
2025/08/26 21:43:35.343045 [TVE] action=screenshot
2025/08/26 21:43:35.420374 [TVE] action=screenshot file=tve_error_screenshot.png size=35606
2025/08/26 21:43:35.420920 [TVE] action=capture_html
2025/08/26 21:43:35.426268 [TVE] action=capture_html file=tve_error_screenshot.html size=56211
2025/08/26 21:43:35.427353 [TVE] action=capture_html
2025/08/26 21:43:35.431298 [TVE] action=capture_html file=tve_error_screenshot.html size=56211
2025/08/26 21:43:36.908436 [TVE] Channel scan HLN failed: Cable provider authentication failed
Saw this same behavior on my test server and a DTV box the other day. It should clear up itself.
Run troubleshooter verifying all green.
Update to prerelease.
Rescan or readd source. If it doesn’t authenticate, wait a couple of hours and rescan.
IMO, I feel this is due to DTV'S implementation of the ESPN/Disney/Hulu rollout!!!
Yup... This cleared itself up. So annoying!
Thank you @jagrim
Still having this same issue here. I have continued to try re-adding the DirecTV Stream source yesterday and today with the same error, so it hasn’t cleared itself up yet for me.
I updated to the 9/4 pre-release and also to the 9/8 pre-release a few minutes ago. Both still have the same issue, with essentially the same log output as the OP.
Try using the DirecTV source instead of DirecTV Stream source
Just tried DirecTV instead of DirecTV Stream source and the same issue exists.
Just to close the loop on this, my issue resolved itself as well.
