DirecTV, Discovery channels not authorizing
Discovery channels ae not authorizing, tried Rescan all channels taking foreve as each Discovery channe; is failing.
Win 11 Latest pre-release 2025.12.12.0245
2025/12/23 22:05:32.664882 [TVE] action=check_result
2025/12/23 22:05:32.673675 [TVE] action=auth_timed_out
2025/12/23 22:05:32.673675 [TVE] action=screenshot
2025/12/23 22:05:32.717100 [TVE] action=screenshot file=tve_error_screenshot.png size=40046
2025/12/23 22:05:32.718182 [TVE] action=capture_html
2025/12/23 22:05:32.720101 [TVE] action=capture_html file=tve_error_screenshot.html size=55813
2025/12/23 22:05:32.720607 [TVE] action=capture_html
2025/12/23 22:05:32.721698 [TVE] action=capture_html file=tve_error_screenshot.html size=55813
2025/12/23 22:05:32.954962 [TVE] Channel scan 60/151 DISCOVERY-LIFE failed: adobe auth reg code: Cable provider authentication failed
2025/12/23 22:05:33.951331 [TVE] action=version product=Chrome/143.0.7499.170 jsVersion=14.3.127.17 protocol=1.3 revision=@81613192193ccffe8b499e9ddd97f85f85c3da25
2025/12/23 22:05:33.958591 [TVE] action=page_ready chromeVersion=143
2025/12/23 22:05:33.959180 [TVE] action=navigate url=https://sp.auth.adobe.com/api/v1/authenticate?deviceType=html5&domain_name=adobe.com&mso_id=DTV&noflash=true&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication&reg_code=Y9BDKJW&requestor_id=discovery
2025/12/23 22:05:33.964209 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2025/12/23 22:05:34.145588 [TVE] action=wait_for_page
2025/12/23 22:05:34.168337 [TVE] action=request type=Document method=POST url=https://idp.dtvce.com/dtv-idp-authn/authn/v2
2025/12/23 22:05:34.168337 [TVE] action=auth_domain domain=idp.dtvce.com
2025/12/23 22:05:34.170031 ERROR: could not unmarshal event: unknown PrivateNetworkRequestPolicy value: PermissionBlock
2025/12/23 22:05:34.219852 [TVE] action=response url=https://sp.auth.adobe.com/favicon.ico status=404 status_text=
2025/12/23 22:05:34.476289 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authorize redirected_from=https://idp.dtvce.com/dtv-idp-authn/authn/v2
2025/12/23 22:05:34.894293 ERROR: could not unmarshal event: unknown PrivateNetworkRequestPolicy value: PermissionBlock
Just tried on my Synology NAS and had no issue rescanning.
Just a suggestion:
Instead of 'Rescan all Channels', scan the individual channel in Manage Lineup section.
Just tried that rescan of only Science, no go, then Food, no go.
At least one other person if having problems with TVE Discovery channels. But I use the DirecTV entertainment package and not having any problems. I am assuming you have run the Channels server Troubleshooting menu selection and insured your Chrome is up to date.
Might check to see if your Win 11 has recently updated and blocking you somehow.
Yes ran Troubleshooting and Chrome is good.
Tried running Discovery Go on laptop Chrome browser for Science then Food
and running Channels in another tab to try to get it to Auth, but no go.
Not clear to me how that could selectively pick the Discovery channels to fail, but Auth the others.
This seems like a recurring problem and the devs usually come up with new pre-releases to try to fix.
It's happened before.
I’m having no problem reauthorizing Discovery networks but I’m running on channels on a Synology server. From your 1st post, you’re on Win 11. I don’t know if native or in a container.
The last Win 11 update broke my connection between my server and my computer forcing me to remap parts of my network.
I’d run the troubleshooter, attempt to reauthorize, then submit diagnostics.
Good luck. Hope you get it going.
