Directv login failing for TVE
I am running 2023.05.19.2045, an older version to provide support on Freenas, I am in the process of setting up a docker instance on PVE but my Directv just started failing over the weekend. Any ideas on the issue?
2023/07/10 09:43:25.854579 [TVE] Auth failed for DTV: Cable provider authentication failed
2023/07/10 09:51:35.636175 [TVE] Auth starting for DTV as [email protected]
2023/07/10 09:51:35.776367 [TVE] action=auth mvpd=DTV requestor=nbcentertainment
2023/07/10 09:51:35.991888 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME url= ip=<nil>
2023/07/10 09:51:35.992475 [TVE] action=version product=HeadlessChrome/76.0.3809.132 jsVersion=7.6.303.29 protocol=1.3 revision=@fd1acc410994a7
a68ac25bc77513d443f3130860
2023/07/10 09:51:35.992904 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=DTV&request
or_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuth
entication
With TVE you want to run the latest prereleases.
Most likely the older chrome
Docker and the latest prerelease here
[TVE] action=version product=Chrome/109.0.5414.74
