Directv Stream - FS1 & B10 out
Directv Stream
Synology
Up to date on pre-release
2025/09/06 23:02:32.102938 [TVE] Channel scan BTN failed: foxsports adobeauth: Cable provider authentication failed
2025/09/06 23:05:55.331207 [TVE] action=version product=Chrome/114.0.5735.199 jsVersion=11.4.183.25 protocol=1.3 revision=@581ada08cf738a4eb44f712c6f8cd40030e5c1a0
2025/09/06 23:05:55.332026 [TVE] action=page_ready chromeVersion=114
2025/09/06 23:05:55.332400 [TVE] action=navigate url=https://sp.auth.adobe.com/api/v1/authenticate?reg_code=4A2XPVI&mso_id=ATTOTT&domain_name=adobe.com&requestor_id=fbc-fox&noflash=true&deviceType=html5&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2025/09/06 23:05:55.336288 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2025/09/06 23:05:55.473346 [TVE] action=wait_for_page
2025/09/06 23:05:55.504733 [TVE] action=request type=Document method=POST url=https://api.cld.dtvce.com/idp/authn
2025/09/06 23:05:55.504797 [TVE] action=auth_domain domain=api.cld.dtvce.com
2025/09/06 23:05:55.829012 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authorize redirected_from=https://api.cld.dtvce.com/idp/authn
2025/09/06 23:06:00.696624 [TVE] action=request type=Document method=GET url=https://identity.directv.com/weblogin/authenticate
2025/09/06 23:06:08.444039 [TVE] action=page_ready
2025/09/06 23:06:08.444192 [TVE] action=wait_for_page done=true reason=page_ready
2025/09/06 23:06:08.444265 [TVE] action=wait_for_auth timeout=12s
2025/09/06 23:06:08.444319 [TVE] action=fill_form u=jagrim
2025/09/06 23:06:08.448851 [TVE] action=tvejs msg="directvLogin: no username"
2025/09/06 23:06:08.449622 [TVE] action=tvejs msg="directvLogin: no password"
2025/09/06 23:06:20.445390 [TVE] action=check_result
2025/09/06 23:06:20.448239 [TVE] action=auth_timed_out
2025/09/06 23:06:20.448301 [TVE] action=screenshot
2025/09/06 23:06:20.525849 [TVE] action=screenshot file=tve_error_screenshot.png size=46248
2025/09/06 23:06:20.526144 [TVE] action=capture_html
2025/09/06 23:06:20.530606 [TVE] action=capture_html file=tve_error_screenshot.html size=56074
2025/09/06 23:06:20.531058 [TVE] action=capture_html
2025/09/06 23:06:20.533936 [TVE] action=capture_html file=tve_error_screenshot.html size=56074
2025/09/06 23:06:21.042570 [TVE] Channel scan FS1 failed: foxsports adobeauth: Cable provider authentication failed
Diagnostics sent.
36048bbb-91d1-4482-9ecf-f3306015e8c9
You sure you're using the latest pre-release?
https://community.getchannels.com/t/dvr-pre-release-notes/28832/9999
Chrome v114 is pretty old.
Mine was running Chrome v129 a month ago when I shut it down.
At the time I started typing the post, both of my servers (Production & Test) were on the latest pre-release. This am I saw a 'new' DVR Prelease topic. I updated both servers to the …0359 version. The Test server authenticated those channels without issue. The Production Server still does not authenticate FS1 & B10 with the same error. Both servers are Synology with channels installed from the Synology package on getchannel.com.
The only difference between the sources is the Directv User Id. I posted 17 days ago about my experience. Both the old and new id's worked on all apps and websites that I tested previously and work on the FoxSports App currently.
As far as Chrome114, it's what Channels or Synology installed as I’ve never fooled with it unless the Troubleshooting Page said to upgrade with a link.
So I have a workable solution that I can initiate when time allows.
Strange.
Are both servers using Chrome v114?
Here are log entries from mine running in the Synology package before I stopped the package last month.
2025/08/03 15:55:16.404992 [SYS] Starting Channels DVR v2025.08.02.2147 (linux-x86_64 pid:25277) in /var/packages/ChannelsDVR/target/channels-dvr/data
2025/08/03 15:56:39.724007 [docker] manifest: repository=chromedp/headless-shell reference=129.0.6668.59
2025/08/03 15:56:39.724088 [docker] manifests: repository=chromedp/headless-shell reference=129.0.6668.59
2025/08/03 15:56:40.853110 [TVE] chromedp-chroot already up to date
2025/08/03 15:56:40.868818 [TVE] Chrome is up to date: 129.0.6668.59
2025/08/03 15:56:41.401110 [TVE] action=version product=Chrome/129.0.6668.59 jsVersion=12.9.202.18 protocol=1.3 revision=@8591405f2525be5aa06c825e3051a243c42a80f1
2025/08/03 15:56:41.402563 [TVE] action=page_ready chromeVersion=129
Yes, both are on the same version.
Chrome version up to date: 114.0.5735.199
If you want to update chrome, here is the way to do it (still works)
Updated Chrome using curl command on both Servers.
  Chrome version up to date: 129.0.6668.59
Still getting failed authentication on FS1 & B10 on Production Server but I’ll get that fixed once Directv allows me to add another source. No issues on Test server.
My steps for adding/removing Directv sources:
Add Directv as source
Confirm source as working
Delete Directv Stream as source
Add Directv Stream as source
Delete Directv as source.
That's quite the dance
I know there's been a history of DirecTV auth failures, like their servers get overwhelmed.
Related issue?
Probably. I’ve now lost TruTV on both servers. It's definitely a DTV / Stream issue. I’ve seen DTV authentication issues increase dramatically since they started rolling out the new free stuff (even on their own platform).
Well, it looks like the authentication servers are back working. I tend to believe @tmm1 that the servers don’t work on the weekend.
Any recent complaints about DirectvStream authentication with TV Everywhere on Channels? I stopped getting my handful of channels (Reelz, CNNI and some others) and thought I needed to rescan. Scan took forever but it seems that it was because all of the authentications were failing. I confirmed I had the right credentials, but I could never get beyond the authentication issue. Is there anything I (or Channels) can do? I've tried for the past 2 days. Thank you.
You don't say if you are using the latest Server Pre-release version, but it is required.
I just scanned a couple of channels and had no issue.
Open sources>Manage>Manage Lineup>Scan then go to individual channel and scan.
Thank you! That was it. There must have been some kind of change as I had not made any adjustments except for the regular updated firmware.
