I was having a number of TCM recordings fail. I did a rescan of my available channels in my Directv Stream subscription, and now am showing basically nothing but 68 "fluff" channels in my Guide. None of the ESPN channels, SEC Network, TCM, etc. I will reboot my Channels DVR Server computer again and see if that fixes the issue.
Download the prerelease which will bring your channels back.
Updating to prerelease
On the DVR web UI, select Status > Version > Check For Update > Check for Pre-Release
I was having the exact same problem and the pre-release has fixed it. Thanks!
I tried and got some channels but not all. I see messages about not being authorized to channels, despite them being part of my package.
A couple of things to try:
1- Run the troubleshooter on the web ui.
If all are green, good. Fix any issue it reports
2. Update to prerelease.
3. Scan individual channels in the sources section of the web ui
Server info would be constructive to post
