Currently when on the guide in ATV, swiping for a certain amount of time enables the scroll bar, which allows you to quickly scroll through the guide. The scroll bar itself is great, but this causes a problem for me where I frequently enable the scroll bar when I don't want it enabled. Actually almost every time I am using the guide. Since swiping on the right-edge of the touch pad already scrolls via the scroll bar, I suggest the following change:
- Disable the scroll bar scrolling when doing repetitive swipes in the guide
- Inform users of the right-hand edge quick scroll capability through a visual or other means
