Hello,
I have been watching an OTA channel and my nvidia shield with channels client seemed to freeze. The fast forward, rewind, pause and play would do nothing. I could bring up the quick guide and navigate, change channels, changed back again and it seemed fine.
Happened a few more times. I have checked the signal on the hdhomerun quattro connect while the channel was not having an issue and the signal looks great. When the issue happened again, I went to check the signal and found nothing connected to any tuners. I have submitted a crash report. Please let me know why this is happening. I had not seen any issues using firetv, but switched to the nvidia shield yesterday
Also, I don't seem to see any issues using a tve stream (so far).
A second OTA channel is showing this issue and after freezing, this is in the hdhomerun log...
20201019-21:37:13 Tuner: tuner0 http stream ended (remote closed)
Thanks
