@doug8796 Please try to submit diagnostics again. It appears something went wrong with the first attempt.
Resubmitted. Do I need to remove and re-add?
Please try updating your password. You are receiving an error that your username or password is bad.
So strange. It works on other sites, but not Channels. I use DirecTVStream
I had an issue once with my DirecTV channels in Channels DVR that got solved once I updated my password. Hopefully, that will do it for you too.
