All of the Discovery Channels are showing Context Canceled. I have Spectrum. I removed it as a provider and readded. This did not fix the problem. I read in some of the older posts that the Science Channel is used for authentication. My package does not include the science channel. Could this be the problem?
They are all working and playing fine in XFINITY.... Are you on the latest prerelease.?
My Spectrum Discovery Networks are working and rescanning properly.
Yes on the latest Pre-release.
In the server web ui update your spectrum password with the same password. This clears the chrome data folder.
In chrome incognito tab can you log in and watch at https://go.discovery.com/live-now
If you can stream from the discovery site try rescanning those channels in the dvr server while it’s playing in another tab
No difference. I can watch from the web browser but when I rescan the channels it still reports context canceled. This is from the log file:
2022/10/30 16:29:22.392855 [TVE] Channel scan 74/217 DISCOVERY failed: context canceled
2022/10/30 16:29:22.635581 [TVE] Channel scan 75/217 FOOD failed: context canceled
2022/10/30 16:29:22.885192 [TVE] Channel scan 76/217 ANIMAL-PLANET failed: context canceled
2022/10/30 16:29:23.135864 [TVE] Channel scan 77/217 HGTV failed: context canceled
2022/10/30 16:29:23.382746 [TVE] Channel scan 78/217 TLC failed: context canceled
2022/10/30 16:29:23.624260 [TVE] Channel scan 79/217 TRAVEL failed: context canceled
2022/10/30 16:29:23.883416 [TVE] Channel scan 80/217 INVESTIGATION-DISCOVERY failed: context canceled
2022/10/30 16:29:24.144668 [TVE] Channel scan 81/217 DIY failed: context canceled
2022/10/30 16:29:24.391709 [TVE] Channel scan 82/217 COOKING-CHANNEL failed: context canceled
2022/10/30 16:29:24.640379 [TVE] Channel scan 83/217 SCIENCE failed: context canceled
2022/10/30 16:29:24.918502 [TVE] Channel scan 84/217 AHC failed: context canceled
2022/10/30 16:29:25.188368 [TVE] Channel scan 85/217 DESTINATION-AMERICA failed: context canceled
2022/10/30 16:29:25.447405 [TVE] Channel scan 86/217 DISCOVERY-LIFE failed: context canceled
2022/10/30 16:29:25.694275 [TVE] Channel scan 87/217 MOTORTREND failed: context canceled
They all work for me .... XFINITY
2022/10/30 13:54:18.398323 [TNR] Opened connection to TVE-Comcast_SSO for ch6101 DISCOVERY
2022/10/30 13:57:42.104828 [TVE] Channel scan 74/217 OWN successful
2022/10/30 13:57:43.080222 [TVE] Channel scan 75/217 DISCOVERY successful
2022/10/30 13:57:43.388097 [TVE] Channel scan 76/217 FOOD successful
2022/10/30 13:57:44.295800 [TVE] Channel scan 77/217 ANIMAL-PLANET successful
2022/10/30 13:57:45.990424 [TVE] Channel scan 78/217 HGTV successful
2022/10/30 13:57:46.755635 [TVE] Channel scan 79/217 TLC successful
2022/10/30 13:57:47.342860 [TVE] Channel scan 80/217 TRAVEL successful
2022/10/30 13:57:47.721203 [TVE] Channel scan 81/217 INVESTIGATION-DISCOVERY successful
2022/10/30 13:57:48.056888 [TVE] Channel scan 82/217 DIY successful
2022/10/30 13:57:48.469461 [TVE] Channel scan 83/217 COOKING-CHANNEL successful
2022/10/30 13:57:50.192014 [TVE] Channel scan 84/217 SCIENCE successful
2022/10/30 13:57:50.643204 [TVE] Channel scan 85/217 AHC successful
2022/10/30 13:57:50.982368 [TVE] Channel scan 86/217 DESTINATION-AMERICA successful
2022/10/30 13:57:51.669726 [TVE] Channel scan 87/217 DISCOVERY-LIFE successful
2022/10/30 13:57:52.060565 [TVE] Channel scan 88/217 MOTORTREND successful
2022/10/30 13:57:52.743347 [TVE] Channel scan 89/217 DISNEY successful
2022/10/30 13:57:52.787978 [TVE] Channel scan 90/217 DISNEYP successful
2022/10/30 13:57:53.146800 [TVE] Channel scan 91/217 DISNEYJR successful
2022/10/30 13:57:53.197655 [TVE] Channel scan 92/217 DISNEYJRP successful
2022/10/30 13:57:53.599389 [TVE] Channel scan 93/217 DISNEYXD successful
2022/10/30 13:57:53.651233 [TVE] Channel scan 94/217 DISNEYXDP successful
2022/10/30 13:57:55.152061 [TVE] Channel scan 95/217 FREEFORM successful
2022/10/30 13:57:55.770561 [TVE] Channel scan 96/217 FREEFORMP successful
What server are you using ... We had a problem in UBUNTU ... but we came up with a workaround.. ?
Windows
I uninstalled both Chrome and Channels and reinstalled them. I am on version 2022.10.03.2116 of Channels as this is the version I had. All of the Channels came back. I will now update to the latest version.
Latest updates: At around 2pm PT today it appears they switched back to the old CDN that does not have a separate audio feed. Recording should be better as long as they are on it.
Additionally, we are working on a new rewriter for TVE feeds that may provide better experiences with Discovery feeds (and potentially others).
PLEASE NOTE: Enabling this new feature may improve your experience, but if there is a bug, it could render TVE recordings made while it was enabled un-watchable. We've done testing as the feature has been developed and don't expect any issues, but this is brand new code, so it could have problems.
If you want to know more about the new rewriter, please check out this thread:
What isn't working? If you're referring to authenticating, these changes will not impact that.
It just hangs on a black screen. It authenticates just fine.
Please submit diagnostics from the app after experiencing this.
Where do I go?
Please go to Settings -> Support -> Submit Diagnostic Logs from your device and let us know when it's been submitted so we can check it out.
