Discovery channels
I have not had Discovery channels for months !
See attached logs.
I tried the fix having the Science channel running in a tab and tried re-scanning Cooking channel and Science channel, both show "No login form found".
I didn't try any others.
Also the Cooking channel plays properly in the direct tab for Science channel tve.
I am using Directv Stream provider, the login and password are correct, other channels do play.
I am on current stable release: Version 2022.03.23.0209
I will try the latest Beta IF a developer says that will fix this, but I'd prefer not to because I have to jump thru hoops on Win 11 to get Beta releases to install, trouble with renaming old release for new release...
and Channels works fine otherwise.
I also have the Notification that I need an update for Chrome, which I did, but still have the warning.
I don't think that will cause the No login form found tho.
Thanks in advance for any guidance on this.
Here is the log for trying to rescan:
2022/05/01 17:49:34.022419 [TVE] action=version product=HeadlessChrome/100.0.4896.127 jsVersion=10.0.139.15 protocol=1.3 revision=@ff0d0695743e65305d7194f9bd309e5e1c824aa0
2022/05/01 17:49:34.023003 [TVE] action=navigate url=https://auth.sciencechannel.com/login-affiliates?returnUrl=https://www.sciencechannel.com/live-now&hostUrl=us1-prod-direct.sciencechannel.com
2022/05/01 17:49:34.023500 [TVE] action=request type=Document method=GET url=https://auth.sciencechannel.com/login-affiliates
2022/05/01 17:49:34.023500 [TVE] action=auth_domain domain=auth.sciencechannel.com
2022/05/01 17:49:34.023500 [TVE] action=scienceauth reason=login
2022/05/01 17:49:36.632322 [TVE] action=wait_for_page
2022/05/01 17:49:42.981755 [TVE] action=page_ready
2022/05/01 17:49:42.981755 [TVE] action=wait_for_page done=true reason=page_ready
2022/05/01 17:49:44.994210 [TVE] action=click_interstitial
2022/05/01 17:49:45.000455 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:45.004590 [TVE] action=wait_for_interstitial
2022/05/01 17:49:46.031014 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:47.043287 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:48.063360 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:49.083181 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:50.102873 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:51.122966 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:52.142764 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:53.163547 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:54.183558 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:55.203681 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:56.207995 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:57.224164 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:49:58.243246 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:49:59.263385 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:00.272792 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:01.293909 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:02.313602 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:03.333446 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:04.352737 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:05.372693 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:06.388611 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:07.392908 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:08.402135 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:09.413138 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:10.424760 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:11.443432 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:12.463265 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:13.482874 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2022/05/01 17:50:14.502585 [TVE] action=tvejs msg="scienceSelect: missing affiliate"
2022/05/01 17:50:15.009314 [TVE] action=wait_for_interstitial err=timeout
2022/05/01 17:50:15.009314 [TVE] action=fill_form u=mguidry15
2022/05/01 17:50:15.011217 [TVE] action=screenshot
2022/05/01 17:50:15.064697 [TVE] action=screenshot size=44396
2022/05/01 17:50:15.065199 [TVE] action=capture_html
2022/05/01 17:50:15.069684 [TVE] action=capture_html size=161052
2022/05/01 17:50:15.070196 [TVE] action=script_error err=&runtime.ExceptionDetails{ExceptionID:1, Text:"Uncaught", LineNumber:9, ColumnNumber:5, ScriptID:"30", URL:"", StackTrace:(*runtime.StackTrace)(0xc002b4d440), Exception:(*runtime.RemoteObject)(0xc00061c750), ExecutionContextID:0, ExceptionMetaData:easyjson.RawMessage(nil)} exp=&runtime.RemoteObject{Type:"string", Subtype:"", ClassName:"", Value:easyjson.RawMessage{0x22, 0x6e, 0x6f, 0x20, 0x6c, 0x6f, 0x67, 0x69, 0x6e, 0x20, 0x66, 0x6f, 0x72, 0x6d, 0x20, 0x66, 0x6f, 0x75, 0x6e, 0x64, 0x22}, UnserializableValue:"", Description:"", ObjectID:"", Preview:(*runtime.ObjectPreview)(nil), CustomPreview:(*runtime.CustomPreview)(nil)} exp_value="no login form found"
The Beta Most likely will. They release a fix a few days after the version you are on.
v2022.03.31.1937
Fixed discovery auth with DTV Stream
and another
v2022.04.21.0314
• IMPROVED: TVE discovery updates
OK, sounds worth a try, thanks for that find and quick reply.
I will have to review my notes on the problem with Win 11 permissions not allowing renaming the old release so the new release can go in.
Will give it a go tomorrow.
Good luck. Hope it works out!
First thing I tried was the simple Check for Updates / Check for Pre-Release.
That worked.
A Win 11 update must have fixed the issue "Folder keeps reverting to Read Only" that gave me trouble.
It did however act a little strange at first, it took a little waiting and playing around for the now authorized Discovery channels to play properly, as follows FYI":
After the pre-release update,
I Rescanned Science channel and Cooking and they both rescanned properly.
I went to a CLIENT and those channels now did not even show up in my Favorites or ALL !!
I Refreshed Source for DTV Stream, it added two channels.
Now they showed up in the Guide with Description but no channel logo and Cooking and Science were at the very top of the Guide, not where they were supposed to be, and when I clicked to PLAY I only got a black screen.
I went to TiviMate (using the Channels DVR m3u) and Cooking and Science showed and played.
I went back to Channels DVR CLIENT and all was now correct, Cooking and Science now in their correct place in the Guide, with channel logo, and they play.
