hello trying to login to dish and direct tv and no luck keep getting for error can someone help out
Need more details to assist. Please share errors from the DVR server logs or submit diagnostics.
2f9e826d-4633-4f70-a331-fadcf8a1f07f here yuo go
so is their a fix it still not working for me
You have a VPN or proxy enabled on your network which is breaking TVE
I don't have any of that my server is here in the usa, i have fubo working and hulu what else can i do to troubleshoot
Are you using a VPS? If so, many streaming providers blacklist the IPs used by hosting providers.
(To the streaming companies, a VPS indicates circumvention of geo-restrictions in the same vein as using a VPN or certain DNS providers. I'm not saying that is what you are doing—there are indeed valid uses for using a VPS, VPN, or other similar scenario. However, the valid uses are far outnumbered by those circumventing restrictions, and so entire IP ranges are blacklisted.)
Are the legit accounts? I find it odd you are paying for Dish/Direct tv/ Hulu and Fubo.
I mean its easy to test isn't it. Is the sub working on the same server without using Channels ?
yeah they are working, and everything was fine until a couple of days ago when they just stopped working i removed and added again and now getting this crazy error
yes they are legit accounts , since this is what we are disputing.thanks for your valuable input. ...smh
im not using a vps a all
Unless the DVR server is in your home it will not work.
