I’m a a DirectTV Stream customer, and today ESPN (and all Disney TVE channels) are giving me this error. The ESPN app works fine, so I do have login credentials working fine. Other TVE channels (like Fox Sports) work fine. Did something change in the new year?
Logs:
3345e0a0-f973-48ad-b9a5-e03debcc7911
Same issue. I actually completely removed it as a source and added again as I thought that would likely solve the issue but it now will not add DirecTV as a source at all.
I have DirecTV and I was just able to watch ESPN in Channels.
So there doesn't seem to be a problem/change either on Disney's side or with Channels.
The problem appears to have resolved itself.
Probably was an issue with the DirecTV authentication servers.
If a channel still has a valid auth token, you won't see an issue until it expires and needs re-authed.
Seems to be better. I'm now able to get around 130+ channels but others are still not authorizing. Some I've resolved by manually scanning each however others are still being stubborn. Hopefully it'll resolve itself soon. I'd probably advise against anyone doing a full rescan with DirecTV/Stream if they can help it at the moment.
