DIY and Science channels failing again-FIXED
Xfinity-TVE
Fails with same error on both Synology pkg (v2021.09.03.2036) and Docker Container (v2021.08.30.2158)
Errors
[ERR] Failed to start stream for ch6108: TVE: 403: Not permitted to watch (access.denied.missingpackage)
[HLS] Couldn't generate stream playlist for ch6108-dANY-ip192.168.1.8: TVE: 403: Not permitted to watch. (access.denied.missingpackage)
[HLS] Stopping transcoder session ch6108-dANY-ip192.168.1.8
[ERR] Failed to start stream for ch6110: TVE: 403: Not permitted to watch. (access.denied.missingpackage)
[HLS] Couldn't generate stream playlist for ch6110-dANY-ip192.168.1.8: TVE: 403: Not permitted to watch. (access.denied.missingpackage)
[HLS] Stopping transcoder session ch6110-dANY-ip192.168.1.8
On the Synology pkg install, rescanning DIY and Science worked
On the Docker install, rescanning DIY and Science both get
chrome failed to start: [95:95:0903/214907.012109:ERROR:browser_main_loop.cc(1390)] Unable to open X display.
So I updated the docker install to the latest prerelease and after a lot of rescan attempts and bouncing the container I got the channels back.
Will this ever end?
