Dizquetv/Channels DVR - shows will only stream in one place
Using dizquetv for streams - Have noticed an issue where the fake channels will only stream in one place at a time - if i try from a second device the channel never loads and just spins forever - channels looks like its trying
It says it is sharing but it doesn't work - this happens on android and apple tv and any combination therein
Let me know what other info you need
Please submit diagnostics from your Channels DVR Server web admin.
Submitted
4e85eefd-b611-43ea-81d8-0cc94ab5459f
Which client device is spinning? May be a video driver setting issue in WSA
I have tested it running on ios and second stream not working on android - and i have also tested it android and android - let me try first stream android and second on ios
Windows Android isn't the problem as I've seen it elsewhere
Yes confirmed - started first stream on nvidia shield
Second stream on 4k apple tv never loads
Everything but nvidia shield is beta release
Wanted to check in on this one - anything i can do?
Not really sure sorry. Is the custom channel setup as MPEGTS or HLS?
This is the current setup
