Docker Hub not working, trying to add Pluto TV
I want to install pluto tv with guide xml but docker hub didn't work. Is there another way ?
Consider a donation to HankLloydRight. He incurs some bandwidth costs.
Set it up as source custom channels and fill in the fields like the pic below
It works! But how come most of the videos don't come with subtitles option?
I don’t ever use subtitles but I’m pretty sure that the docker version has the same issue you could probably search Pluto closed captions for better info on it
oh ok thanks! Do you know any other m3u files I can use?
Samsung tv plus, stirr. I’m sure there are probably a couple more.
