Does anyone know of a good tutorial for using Docker?
I'd like to use the frndly add on for docker, and the one for MLB if there's a baseball season.
Depends where you're planning to run it. The tutorial would be completely different for PC vs Mac vs Synology vs QNAP
Sorry, I'll be using it on my Synology DS720+
Maybe this will help: Creating a container | Docker - Synology Knowledge Center
There's also lots of videos on youtube if you search for synology docker tutorial
The keyword was Synology. I was just searching for docker because I didn’t know it was specific to what you were using. Thanks for the help!
