I just started using the app on my iphone 6s. When I create a new series pass, the pass shows up twice in the “Your Passes” list. If I force quit the app and re-open, it correctly displays just one pass for the series.
How did you create the pass?
Search for the show on the DVR tab. Select the show then press Create a Series Pass. Changed some options then added using the button at the bottom. It doesn’t seem to happen every time. The app will crash if I try to delete both of the new passes. The first delete works correctly, but the second delete results in the crash.
