On the iPad and iPhone, YouTube allows you to skip back or forward if you double tap the left side or right side of the screen.
I’d like to see this incorporated with Channels. Easy than tapping the screen, seeing the controls, and them tapping the skip back/ forward controls.
And you could even add triiple tap on the right side on the screen to skip the commercials.
