Everything was working fine until I switched to CenturyLink the other day. Now all my remote access is hosed. Each time I try to remote access Channels DVR using my iOS app, I get the message 'Your Channels DVR Server at home can not be reached. Remote access is enabled, but we can not reach your server. Please ensure that port 8089 has been properly forwarded, etc, etc'. As you can see from the message I do have remote access enabled.
This is my setup: I'm using the CenturyLink provided Zyxel C3000Z modem with a Google Wifi router. I've set up port forwarding in the router for port 8089. If I go to check-host.net with my IP:8089, all connections time out. Looking at my CenturyLink firewall settings, security is set to low with mostly everything allowed. Only things not allowed are Windows Remote Management are Windows Messaging.
Because everything started with the change to CenturyLink, it seems that's where the issue lies, but I can't pinpoint what.
On a side note, I also lost remote access to my Plex server as well with message 'Looks like your server may be connected to the internet through multiple routers or other network devices'. I'm obviously not looking to solve that here, but I thought I would mention it in case it helps with troubleshooting the Channels DVR issue.
Any help would be greatly appreciated.
