For a while I have been using two DVRs in order to re-map channel numbers, the TVE sources from "DVR1" are piped to "DVR2" via a custom source M3U playlist in MPEG-TS format.
This has been working great until recently, I am constantly loosing connection with this error message...
Couldn't generate stream playlist for ch135-dANY-ip10.10.10.1: Playlist has not been updated in 20.845912378s
The error is always 20.XXX seconds and seems to be happening across all channels. I have submitted diagnostics under user DCLeslie as well. Have there been any changes to how the DVR caches the TS segments that would be causing this issue to only occur since the 1/23 DVR release?
