I'm seeing transcoding issues on my DS916+ recently (not sure when exactly it started), where it's no longer able to transcode at 1x or faster. Seeing closer to 0.3-0.5x. Playing material recorded from HDHR Connect.
Seeing the following in the log (this includes a skip forward):
2020/06/02 16:44:05.497148 [ENC] Starting encoder for Late Night With Seth Meyers S07E107 Anna Kendrick Action Bronson 2020-06-01-2336.mpg in /volume1/media/DVR Recordings/Streaming/file2659-ip192.168.0.13-134218809/encoder-138-323381971 at 138 (157.960356) (encoder=h264_vaapi, resolution=1080, deinterlacer=blend, bitrate=10000 segment_size=0.01)
2020/06/02 16:44:05.512698 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x2ca16c0] Dropped corrupted packet (stream = 1)
2020/06/02 16:44:05.512755 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x2ca16c0] Dropped corrupted packet (stream = 2)
2020/06/02 16:44:05.513170 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x2ca16c0] stream 1 : no PTS found at end of file, duration not set
2020/06/02 16:44:05.513226 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x2ca16c0] stream 2 : no PTS found at end of file, duration not set
2020/06/02 16:44:05.530464 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x2ca16c0] Dropped corrupted packet (stream = 1)
2020/06/02 16:44:05.530537 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x2ca16c0] Dropped corrupted packet (stream = 2)
2020/06/02 16:44:20.345720 [ENC] Request for 164 is more than 10 from the last encoded segment of 144
2020/06/02 16:44:20.368562 [ENC] Stopped encoder for Late Night With Seth Meyers S07E107 Anna Kendrick Action Bronson 2020-06-01-2336.mpg in /volume1/media/DVR Recordings/Streaming/file2659-ip192.168.0.13-134218809/encoder-138-323381971 after encoding 138 to 144
2020/06/02 16:44:20.369552 [ENC] Starting encoder for Late Night With Seth Meyers S07E107 Anna Kendrick Action Bronson 2020-06-01-2336.mpg in /volume1/media/DVR Recordings/Streaming/file2659-ip192.168.0.13-134218809/encoder-164-231411734 at 164 (184.420122) (encoder=h264_vaapi, resolution=1080, deinterlacer=blend, bitrate=10000 segment_size=0.01)
2020/06/02 16:44:20.385239 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x380c6c0] Dropped corrupted packet (stream = 1)
2020/06/02 16:44:20.385311 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x380c6c0] Dropped corrupted packet (stream = 2)
2020/06/02 16:44:20.385723 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x380c6c0] stream 1 : no PTS found at end of file, duration not set
2020/06/02 16:44:20.385777 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x380c6c0] stream 2 : no PTS found at end of file, duration not set
2020/06/02 16:44:20.400621 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x380c6c0] Dropped corrupted packet (stream = 1)
2020/06/02 16:44:20.400671 [HLS] ffmpeg: file2659-ip192.168.0.13: [mpegts @ 0x380c6c0] Dropped corrupted packet (stream = 2)
2020/06/02 16:44:32.988186 [ENC] Stopped encoder for Late Night With Seth Meyers S07E107 Anna Kendrick Action Bronson 2020-06-01-2336.mpg in /volume1/media/DVR Recordings/Streaming/file2659-ip192.168.0.13-134218809/encoder-164-231411734 after encoding 164 to 169
Settings are, I believe, on the defaults:
Transcoder: Hardware
Deinterlacer: Blend
Adaptive Streaming: On
Web player settings:
Server Quantity: 1080p @ 10mbps
Client Buffer: 30s
DVR version: 2020.05.25.2131
Tried both Chrome and Safari (both on MacOS) to see if it might be a client issue, same behavior on both. Client computer is wired to NAS over 1Gbps link.
Is there a setting I should change somewhere, perhaps?
