DSM 7.4 starting to roll out
Are there known compatibility issues?
-- Edit -- Upgraded to 7.4 and all seems well. Thanks for the responses !!
Haven't got the DSM 7.4 update yet (staged rollout), but I don't see any breaking changes in the release notes.
Compatibility & Installation
  1. To ensure compatibility, the following packages will be automatically updated or will require a manual update to a compatible version: Synology Chat Server, HighAvailability(SHA), Synology MailPlus Server, PACS, QuickConnect, ReplicationService, SecureSignIn, SnapshotReplication, WebStation
  2. PHP 8.1, Mail Station, and Synology Mail Server are no longer supported.
What's New
  1. When DSM joins an LDAP server, it now displays the supported SMB authentication methods, allowing you to identify whether LDAP users can use NTLM, CIFS plaintext authentication, or Kerberos.
  2. Added display for GPU information in Info Center.
  3. Enhanced KMIP certificate handling to align with updated public Certificate Authority (CA) certificate issuance policies. Synology certificates now support exporting an additional CA file for KMIP client authentication. This update also adds Log Center records for failures caused by expired Synology certificates and improves KMIP interface messages for expired certificates.
Why do you ask?
I just installed DSM 74 and all is working here.
downloaded the file from the download center on their website. The system rebooted and Channels along with my containers came back online.
No problems here as well
Channels is the one key Non Synlogy App on the NAS
